1972 SR20DE Datsun 510 semi-track car trade....
Cryingsuns
Postby Cryingsuns » Fri Oct 23, 2015 11:40 pm
1972 Datsun 4-door for trade only for Hatchback GT-S only!
If there's a price: 13k....but for trade only!
Cash on your side or cash on my side. If you think your car is worth 10K or more let's figure this out. My parts list is no joke, speaks for itself. I'm forthcoming on all issue's so read through and contact me with additional questions. I have two Datsuns and I want to give this one up for a Corolla.
Info: The car has a bit of surface rust, when I say a bit, there's a bit, the paint for the most part is great, the two front fenders have small dents. The car was completely repainted in 2009. Small dent on passenger side rail. There's no carpet, and the dash pad needs to be replaced. The cat back exhaust is garbage, you'll want a something of more quality. There's a small short, there is switch for that issue, I'm also testing to find it. The battery drain is about 2 weeks of sitting. All the parts are quality, top notch **** in good condition. Needs the windshield motor, wipers do not work. The swap was done by Signal Auto before they closed their doors and went back to Japan. The car is amazing on the track, there's nothing in the way of suspension that needs to be done.
I can send additional pics upon request.
Contact info:
Remkoart@gmail.com
(619) 665.0591
Located in San Francisco <---------------------------
SR20DE-S14 Knotchtop
69' Bumper, license plate light
New rubber around windows, trunk and doors
Rear bumper (rear bumper needs some love), rear light frames, headlight covers re-chromed
New gaskets
Exedy stage 1 clutch
RSR header (modded for LHD)
New water pump
Nismo thermo
New alt
Greddy oil pan
Greddy pulleys
Greddy catch can
TSR alum rad W/ twin fans
TSR custom fuel lines
RCI 10 gallon fuel cell
2 Bosch fuel pumps,
Custom surge tank all Earl fittings
Sard fuel regulator
R-160 SUB LSD
Nismo engine mounts
Datsport swap kit/full swap kit (Datsport.com)
Datsport control arms
Datsport front sway bar
DP-Design products coil overs ($$$$)
DP-Camber plates
Roll center adjusters
TEIN strut tower bar modded by TSR
15x7 -1 SSR Longchamps 15x7.5 +6 SSR Mark III
TOYO 185/55/15 tires 98% tread
NISMO extended studs
DEFI temp
DEFI oil pressure
DEFI tach
Buddy Club Ground kit
Modern fuse set-up
Nardi steering wheel
WORKS Bell quick release and lock cover
Bride reclining ergo seats with custom rails, and harnesses
Theft security
Push button start
Duel Fuel switch toggle system
Battery switch cut-off
Battery relocation (rear-seat)
Cryingsuns
Re: 1972 SR20DE Datsun 510 semi-track car trade....
Postby Cryingsuns » Thu Nov 12, 2015 8:15 am
Getting some very nice coupe offers...seems no one wants to let go of their Hatchi's. :/
Cryingsuns
Postby Cryingsuns » Wed Dec 23, 2015 4:12 pm
Update*** Car will 14x7.5 -8 Longchamps, mint condition dash pad (hard to find), door cards, and will have carpet in Jan.
Once I get the b pillars re upholstered and head liner I'll just keep the car.
Really want a hatchi but there's no offers between the 10-14k range. :/
