86 turbo bmw e30 trade for ae86
Sir_nick742
Postby Sir_nick742 » Thu Jan 24, 2013 7:49 pm
Contact: 661-599-4629 or email vgmoto300@gmail.com
Located in tehachapi
UPDATE: did a compression test right now 1-21-13 150-155psi across the board. Service manual says 156psi is nearly perfect so this motor is very very healthy.
Clean title
Tags up to date till June
80% on tires
Good brakes
New vacuum lines
Fresh oil change
New Bosch premium spark plugs
New Bosch premium spark plug wires
New distributor cap
Newer clutch fan, other one was getting old
New coolant hoses
New timing belt
New water pump
New oem exhaust manifold gasket
Brand new exhaust all the way back with a cat
Chipped ecu
No oil leaks or coolant leaks
Front mount intercooler with 2.5inch piping
Cone filter
New starter
Stage 1 clutch
LSD rear end
Shift knob
Working sunroof
.63 trim turbo t3/t4 with internal waste gate on 5psi
Euro hella headlights
Boost gauge
All power windows work
Heater works
Lowering springs
New ujoint and carrier bearing
All gauges work
All lights work
Hks blow off valve
Pioneer speakers
Is front bumper
Is spoiler
New battery
Cons:
No passenger seat
Few small dents and dings here and there
No a/c or power steering
Could use a wheel balance
Has a ticking noise from the driveshaft it needs a new guibo but no damage is being done
Car runs strong pulls hard doesn't smoke. is my daily driver.
Car is built to be reliable
No over heating
Inside the motor is extremely clean, car also has new freeze plugs in block leading me to believe the motor is rebuilt but I have no proof.also the really high compression test numbers are another sign.
Sir_nick742
Re: 86 turbo bmw e30 trade for ae86
Postby Sir_nick742 » Mon Jan 28, 2013 10:42 am
Bump one still looking
kuroki86
Postby kuroki86 » Mon Jan 28, 2013 1:45 pm
cool e30, bet it's fun
Sir_nick742
Postby Sir_nick742 » Mon Jan 28, 2013 8:45 pm
Thanks, yeah it's a lot fun and fast.
Sir_nick742
Postby Sir_nick742 » Thu Feb 07, 2013 10:26 pm
Bump this up
