cheap welding service.
runkillerrabbit
Postby runkillerrabbit » Tue Mar 19, 2013 2:52 am
at the moment i have a small mig and can weld almost any steel.
ill be getting a tig soon so ill be doing aluminum soon.
let me know if you need anything small or non safety related.
i dont do roll cages. too much liability. and pipe angles and physics you actually have to learn. havent done any research on it. will do it when the times comes for me to need it.
but if you have a hole in your firewall because the meat head before you cut out a big gaping hole for a dizzy ( why i learned to weld), i can plug it up!
ill post some pics
also im doing a r1 carb conversion and im making the intake manifold for it
and then ofcourse f20 conversion with the custom driveshaft and all. ofcourse thats later later.
benchung at rocketmail dot com
thanks club.
im in paramount, ca.
FIDM fashion design
ITT tech electrical engineer
FJC Fullerton automotive program
R2D2 build log
runkillerrabbit
Re: cheap welding service.
Postby runkillerrabbit » Sun Mar 24, 2013 5:44 pm
bump
FIDM fashion design
R2D2 build log
