RPM Auto Parts-Toyota Corolla AE86 OEM Parts....and more.
Posted: Fri Feb 08, 2013 9:40 pm
RPM Auto Parts AE86 Parts Inventory Availability list.
KOYO OEM Front Wheel bearing & Seals Set Left and Right sides
2 Outer Wheel Bearings koyo Made in Japan
$65.00 Free Shipping in U.S.A.
(For 1 side only Left or Right $35.00)
Performance Front and Rear Cross drilled and Slotted or Slotted only rotors set of 4 Gold Zinc Plated anti-corrosion
2 Front Performance rotors (Must chose Drilled and slotted or Slotted only)
2 Rear Performance rotors (Must chose Drilled and slotted or Slotted only)
$120.00 Free Shipping in U.S.A
Performance Front and Rear Cross drilled and Slotted or Slotted only rotors set of 4 Gold Zinc Plated anti-corrosion with PBR Brake Pads
1 Front set PBR brake Pads
1 Rear set PBR brake Pads
$165.00 Free Shipping in U.S.A
Toyota Corolla 4AGE 16V RPM Aisin Water Pump & Timing Belt kit
1 Aisin Water Pump
1 Mitsuboshi Timing Belt
1 Koyo Tensioner
2 THO Cam Seals
1 THO Crank Seal
$130.00 Free Shipping in U.S.A
Toyota Corolla 4AGE 16V RPM Aisin Water Pump & Timing Belt Gasket kit
1 Aisin Water Pump
1 Koyo Tensioner
2 THO Cam Seals
1 THO Crank Seal
1 KP/THO Valve Cover Gasket Set
$160.00 Free Shipping in U.S.A
Toyota Corolla 4AGE 16V RPM Aisin Water Pump & Timing Drive Belt Gasket kit
1 Aisin Water Pump
1 Koyo Tensioner
2 THO Cam Seals
1 THO Crank Seal
1 Bando/Mitsuboshi A/C Belt
1 Bando/Mitsuboshi P/S Belt
1 Bando/Mitsuboshi Alt Belt
$185.00 Free Shipping in U.S.A
THO Valve Cover Gasket Set 4AGE
1 THO Valve Cover Gasket Set 4AGE Made in Japan
$35.00 Free Shipping in U.S.A
Aisin OEM Clutch Master Cylinder AE86
1 Aisin Clutch Master Cylinder AE86 Made in Japan
$38.00 Free Shipping in U.S.A
Aisin OEM Clutch Slave Cylinder AE86
1 Aisin Clutch Slave Cylinder AE86 Made in Japan
$36.00 Free Shipping in U.S.A
1 Aisin Brake Master Cylinder AE86 Made in Japan
$89.00 Free Shipping in U.S.A
Taiho Engine Bearing Set 4AGE
1Taiho Main Bearing Set Made in Japan
1Taiho Rod Bearing Set Made in Japan
$85.00 Free Shipping in U.S.A
NPR Piston Ring Set 4AGE
1 NPR Piston Ring Set 4AGE STD. Size Made in Japan
$45.00 Free Shipping in U.S.A
AE86 Ball Joint (Aftermarket)
1 AE86 Ball Joint CTC/Parts Master
$22.00 Free Shipping in U.S.A
2 AE86 Ball Joints CTC/Parts Master
4AGE 20V Parts
Sprinter Trueno AE86 Front Grill Emblem
Sprinter Trueno AE86 Front Grill Emblem 75314‑12021 $85.00 Free shipping in U.S.A
KP Made in Japan Head Gasket Kit Engine Valve Grind Set
KP Made in Japan Head Gasket Kit Engine Valve Grind Set 04112-16330 / 0411216330 $245.00 +shipping in U.S.A (imported from Japan) only 5 available
Toyota Corolla Levin Sprinter Trueno AE86 Stripe GTV TWIN CAM 16 Sticker
Toyota Corolla Levin Sprinter Trueno AE86 Stripe GTV TWIN CAM 16 Sticker 75985-12380 / 7598512380 $110.00 pair (as shown) + shipping in U.S.A (imported from Japan) only 2 available
Toyota Corolla Levin Sprinter Trueno AE86 Stripe GTV TWIN CAM 16 Sticker 75985-12380 / 7598512380 $60.00 Each individual + shipping in U.S.A (imported from Japan) only 5 available
1 Aisin Water Pump
1 Koyo Tensioner
2 THO Cam Seals
1 THO Crank Seal
1 Aisin Water Pump
1 Koyo Tensioner
2 THO Cam Seals
1 THO Crank Seal
1 Aisin Water Pump
1 Koyo Tensioner
2 THO Cam Seals
1 THO Crank Seal
4AGE 20V Parts
