Here are a few parts that we can offer for the AE86. We can also offer parts for other vehicles as well. If you do not see what you are looking for, do not be afraid to ask!
Buddy Club:
Spec II Exhaust
$450
Seat Rail (Left or right)
$140
Mishimoto:
Aluminum Fan Shroud w/fans
$180
Aluminum Radiator
$240
Cusco:
Tow Hook Set
$90
Front Sway Bar
$225
Rear Sway Bar
$215
Roll Center Adjuster (RCA)
$175
Roll Center Adjuster (Rear)
$70
Shift Lever Collar
$28
LSD Type RS (1&2, 1.5, or 2 way)
$1050
Camber Plates
$260
Oil Catch Can
$110
Lateral Rod
$180
Front Strut Bar (Carbon OS)
$200
Front Strub Bar (OS)
$180
Rear Strut Bar (OS)
$180
Engine Mount
$110
Transmission Mount
$55
Tomei:
T-Trax LSD
$700
ACT:
HDG4 Kit
$340
HDG6 Kit
$360
Apexi:
Hybrid Megaphone EVO
$750
Bomber 3
$480
Bride:
RO Seat Rail (Left or Right)
$200
Exedy:
OEM Clutch Kit
$110
Stage 1 Clutch Kit
$280
Stage 2 Clutch Kit
$300
Goodridge:
SS Brake Lines (5 line kit)
$160
Injen:
Short Ram Intake (USDM)
$200
Koyo:
Aluminum Radiator
$280
Project Kics:
Magnetic oil Drain Bolt
$25
Project Mu:
B-Force Pads (Front)
$140
B-Force Pads (Rear)
$135
Club Racer (Front)
$180
Club Racer (Rear)
$160
NS (Front)
$120
NS (Rear)
$110
Samco:
Radiator Hose Clip Kit
$18
Radiator Hose Kit (Black, Red, or Blue)
$80
Tanabe:
Front Sway Bar
$200
Rear Sway Bar
$200
GF210 Springs
$180
Tomei:
Forged Piston Kit (81.5mm or 82mm)
$1500
Forged H-Beam Connecting Rod Kit
$600
Exhaust Manifold Gasket (38.0-0.8mm)
$115
Timing Belt (16v)
$145
Adjustable Cam Gear (16v)
$110 each
Flywheel Bolt Set:
$99
Head Studs (16v)
$305
Main Studs
$240
Crank Cap Ladder Set
$225
Main Studs & Ladder Set
$450
Rim and Tire Center - Aftermarket AE86 Parts
Re: Rim and Tire Center - Aftermarket AE86 Parts
bump! for travis
Rays - Project Mu - TE37 club
BLUE MOON / CUSCO
AE86fightclub.com
PM me for Contact
BLUE MOON / CUSCO
AE86fightclub.com
PM me for Contact
