$1000 shipped in continental USA
Complete set of Epsilon mesh. Assembly and work required however. No tires.
Specs:
ALL made from 548 hoops
Since this set was made from all rear hoops, there is no drop center. So to mount and dismount tires you can't use a conventional tire machine. You would also need a "cheetah" to seat the beads. As long as you assemble them correctly and use the right silicone, you won't have leaks.
Four 15x9.5 -27 4x114.3 (gray and black faces) Two are completely put together, the other pair needs to be assembled.
All four faces Need center bores to be welded along hairline stress fractures.
Only ONE rear hoop needs to be SLIGHTLY straightened along the outer flange. Honestly it's nothing major.
pic of hairline fracture
FS - Epsilon mesh 15x9.5 -27 4x114.3 set norcal
Re: FS - Epsilon mesh 15x9.5 -27 4x114.3 set norcal
for everyone concerned about mounting tires. this is what you're "tire" people should have..........
one of these
and one of these
and DON'T USE ONE OF THESE.
one of these
and one of these
Do you have pictures of the lug holes i'm interested in them if they aren't too bad . Also could you take pics of the back of the face .
its the first picture. all the lug holes have those tiny fractures running down the sides like in that picture.
So it has it around the center bore as well as the lug holes . If you could pm me the best you could do shipped to 22405
I'll take em for $1000 shipped to 98230 if you have all the nuts and bolts (hardware) for the wheels. PM me.
It only has those hairline fractures on the the center bores. Thanks for the correction. Ad fixed. and pmed
