Selling 40mm Dell'orto DHLA and 20R head
Selling a set of 40mm DHLA Dell'oto carbs with Mikuni manifold for a 20R and a ported big valve 20R head. Carbs come with extra chokes, jetting and emulsion tubes, new K&N filters and rebuild kits. Head has not been used since it was built. Installed 45mm intake and 37.5mm exhaust valves, ported and matched to this manifold. Head has NIOT been modified for installation on later 22R 'Laser' blocks. Available with these parts is a Mallory Pro pump and Holley pressure regulator, maybe an MSD 6AL and tach adapter. $650 for the carbs, $1200 for the head, $150 for the fuel pump and reg, $150 for the MSD bits. $1800 for all. Might consider trades.
One shot, one kill.
Re: Selling 40mm Dell'orto DHLA and 20R head
Do you have the linkage setup for the Carbs i need it for a 4AGE.
The carbs are set up for a center cable pull.
One shot, one kill.
