JDM block w/oil squirters
sirdeuce
Postby sirdeuce » Mon Sep 25, 2017 9:12 am
Selling a few things here. Plus shipping. Or pick up if local. Located Pismo CA area.
JDM block from a high comp 4AGE with oil squirters, standard bore. $250
40mm crank and rods, rods have 18mm wrist, comes with ARP rod bolt set(uninstalled). $150
Light weight flywheel. $200
Take all for $500
Also have a set of
40mm rods with pistons attached. $40
Aftermarket high comp 20mm wrist pistons, .5mm/.020" over, no rings. $25
Aftermarket 18mm standard pistons with NPR rings. $45
NPR 1.5/1.5/2.5 .5mm/.020" over rings. $25
Total seal rings 1.5/1.5/2.5 standard. $50
200mm flywheel $40
One shot, one kill.
original menace
Re: JDM block w/oil squirters
Postby original menace » Tue Nov 07, 2017 7:15 pm
i'm interested in the crank
