WTS - 4AGE Parts - AE86/MR2/ BP/SP/BT/ST (updated 12/7/16)
AEatesix
Postby AEatesix » Mon Oct 31, 2016 12:16 am
Respond to the ad ONLY if you have any questions or if you're interested in any of the listed items. Open to offers/some trades. Willing to ship/paypal at your expense. List will be further updated, feel free to ask me if you're looking for something not on here. I DO NOT HAVE ANY Fuel lines/tank, injectors, T-50 transmission parts or rear-end stuff.
Text Chris @ - Six 0 Two Nine ATE 9 05NineFive
I'll check messages on here slower than texts
20v Silvertop parts:
ST High-comp Domed Pistons (came out of a clean block): $200
Timing Belt (Toyota low miles): $20
Silver Top - Air Box w/ Gasket: $60
AirBox Gasket: $10
Black Top - Lower half of the air box: $25
4AGE Parts:
4AGE Valve Covers (pair) - $40
4AGE Red-top Cam Gears - $60
4AGE Bluetop MR-2 ECU - $40
4AGE BlackTop Ignition Control - $75
4AGE BlueTop Ignition Control - $50
4AGE Ignition Coil (denso) - $60
4AGE Distributor w/shield (no cap) - $75
4AGE MAFS - $65
4AGE Throttle Body - $60
4AGE TVIS Plate /w switch - $50
4AGE EGR Setup - $60 (connects from the back of the intake manifold, to the EGR assembly then around to banjo bolt on the exhaust manifold)
AE86 Intake Box w/ Snorkel - $200
AE86 Intake Box w/o Snorkel - $100
AE86 Intake Box Top - $50
AE86 Intake Manifold (RWD) - $100
AE86 Flywheel (blue top AE86/RWD): $50
MR2 Intake Box - $100
MR2 Intake Manifold (MR-2/FF) - $100
MR2 Waterlines - $30 each
MR2 Engine Wiring Harness (MR-2) - $150
MR2 Exhaust Manifold (MR-2/FF) - $100
20v Header (MR-2/FF) - $150 (may need a notch cut in corner bolt to adapt to non-20v)
16v Small Port Water Line (back of the water pump) - $50 (PENDING)
AE86 parts:
-Interior-
Trunk/Gas door lever - $10
Front Ash Tray(drawer) - $20
Dash coin holder insert - $15
Gauge Cluster Bezel - $20 (it's not in perfect condition)
GTS Driver's Seat Lumbar Support (black pump/works great) - $25
GTS Seat Plastic sides - $10 each
GTS Steering Wheel (Fair) - $15
Hatch Center Brake Light - $40
Hatch C Pilar Plastics - $40/each
Hatch Rear Plastic w/light (BLK) (missing one strut access cover)
Hatch Rear speaker housing/cover (Maroon/Passenger side) - $25 / each (needs some wet sanding and trim paint/sealer, but the plastic isn’t brittle and is fully intact)
Map light plastic control - $25
Front Seatbelts (blue) - $20 each
Front Seatbelt Buckle (black)- $20
Rear Side cards (BLK) - $20 each
Rear Bench Seat (BLK) - $50
Rear Seatbelts (black) - $20 each
Rear R or L Seatbelt Buckle (black) - $15
Rear Center Seatbelt Buckle (black) - $15
SR5 Steering Wheel (good) - $20
- Exterior -
Moon Roof Panel - $100 (SOLD)
Coupe Quarter Window Glass - $100 each
Door Window Glass - $150 each
GE headlight bulbs - $5/each
Rear Side Marker Lens - $10/each
Front Blinker Lens - $15/each
Windshield Wiper Arms - $30 each
Coupe Trunk Lid - $100
GTS Zenki Front Bumper Sides - $35/each
GTS Zenki Front Grill - $40 (does not include the emblem)
Headlight Skin - $25-40/each (depends on condition)
- AC -
Single Dash Vents (blue or black)- $10/each for better shape ones, discounts offered on the imperfect ones.
Double Dash Vents (blue or black)- $15/each for better shape ones, discounts offered on the imperfect ones.
Circular Dash Vents - $10/each
Ducting (to back seats, under front seats) - $50/each
Hard lines: $20 each
Evaporator: $50 (without Amplifier/cover)
AC Compressor Manifold: $100
AC Compressor: $30 (not sure if it works, doubtful)
- Power Steering -
Power Steering Lines: $15 each
Reservoir Tank: $40
Power Steering Rack: $40 (comes with functional tie rods)
Power Steering Pump Core: $20
Bracket and Tensioner pulley: $100
-Suspension/Braking-
Front Calipers (need rebuilding) - $30/each
Stock Steelies (no tire) - $15/each
Stock Snowflake Wheels - $150/ all 4
MR2 Parts:
Radio housing plastic - $30 (uncracked plastic)
Gauge cluster - $50
rear caliper set (pair) - $50
front caliper set (pair) - $60
Emergency brake handle - $25
Front blinkers - $20/each
Windshield Wiper Motor - $15
More to be listed....
Misc:
TE Silver Lisc. Plate light - $10
Individual vintage hub caps - incomplete set fillers - $15/each
4A-FE Distributor (works but has a slow inner leak) $20
4A-FE head - $25 (comes with gaskets/missing journals and cams)
4AGE Redtop spark plug wires by denso- never used/new - $30
AEatesix
Re: WTS - 4AGE Parts - AE86/MR2/ BP/SP/BT/ST (updated 12/7/16)
Postby AEatesix » Wed Dec 07, 2016 2:00 pm
bump for updates :)
kim julio
Postby kim julio » Mon Jun 05, 2017 10:02 pm
hello
you have rear outlet return ae86
and thermostat for ae92?
