Silvertop engine/trans/ECU & Wiring Harness - Updated 1-28-1
daveh
Postby daveh » Fri Jan 25, 2013 2:01 pm
Toyota 4A GE 20 valve Silvertop engine for sale. Running takeout from a LeMons race car. Last raced at Road Atlanta December 8th. Includes 5 speed trans (front wheel drive), ECU, AFM and complete wiring harness including coil and ignition controller. Engine was rebuilt in 2011 with new rings and bearings, water pump and oil pump. Pistons coated by Swaintech. 1mm oversize valves by Supertech. Ported head. Block has been trued and align honed. Billett aluminum crankshaft pulley and undersized water pump pulley. Extrude honed exhaust manifold (includes exhaust manifold and headpipe with O2 sensor). New Stage 1 Spec clutch used for 1 race. Lightened "Blacktop" flywheel. ARP hardware throughout.
Compression in one cylinder is a bit lower than the other 3 (188psi -vs- 210). Engine runs fine. A new set of rings and gaskets included. - $1,000
Wiring diagrams, etc. included.
Best Offer - Located in New Jersey
E-Mail me for questions, pictures and complete list of parts - jetski983@aol.com
agonzales03
Re: Silvertop engine/trans/ECU & Wiring Harness - Updated 1-
Postby agonzales03 » Tue Jan 29, 2013 6:30 pm
How much for Engine and Harness only?
daveh
Postby daveh » Tue Jan 29, 2013 7:16 pm
I assume this means no trans, ECU, clutch, flywheel or oil cooler?? $800 for the engine and wiring harness including the extra set of rings and gasket set.
You pick it up in NJ.
let me know..
THEBOSS419
Postby THEBOSS419 » Tue Feb 05, 2013 7:22 pm
how much for just the harness+coil+ignition controller?
daveh
Postby daveh » Tue Feb 05, 2013 8:42 pm
I do not want to sell these separate from the engine.
Sorry
Dave h
