Stuffs for sale
aukword1
Stuffs for sale
Postby aukword1 » Fri Aug 18, 2017 6:24 pm
Located in Socal, will ship at buyers expense.
4AGTE w/ Custom Intake manifold, NST Adjustable Cam Pulleys, etc.. - $old
T50 Transmission - $old
GTS Driveshaft - $100
Megasquirt PNP Gen 2 ECU - $old
Snow Performance Boost Cooler Stage 2 water/methanol Injection kit - $200
5 Gallon Drum of Pure Methanol - $50
Oversized Aluminum Radiator w/ Fans - $old
HKS 272 and 288 cams 8.1 lift - $old
Prothane bushing kit (minus front and rear sway bar bushings) - $50
OEM front LCA's - $75
OEM tension rods - $50
OEM rear four links - $50
OEM front hubs - $150
OEM front calipers - $old
EGR system - $150
USDM AFM - $35
USDM 16v GTS ECU - $100
Big Port Head 16v - $200
3 rib Block - $150
GTS oil cooler w/ OEM sandwich plate - $100
FC Calipers - $old
OEM 16v ignitor/coil - $50
16v Distributor with new rotor and cap - $80
SQ Engineering Distributor Cover Plate - $old
OEM Intake Manifold 16v - $old
PS Steering rack - $old
Megan PS outer tie rods - $30
Megan rear four links - $100
KSD EGR block off plate - $old
OEM throttle body w/ good IACV Valve $100
PS Steering knuckles - $old
16v bigport TVIS assembly - $45
OEM front caliper brackets and dust cover - $50
4x 1zz coil packs - $old
new 1zz coil pack connectors x5 - $old
2x 1zz pigtail harness - $old
3SGE Beams Intake manifold - $50
3SGE Beams Throttle Body - $50
3SGE Beams MAF - $50
3SGE Beams Apexi Intake BNIB - $old
3SGE Beams Apexi Intake Slightly Modified but unused - $old
Zenki rear Axles w/ good bearings - $150
Rear Caliper Brackets - $old
+ more parts to come
Picture gallery link - https://postimg.org/gallery/364i3e0ju/
PM me or text me if you have any questions or want any pictures at (714)856-0062.
Thanks!
85levin
Re: Stuffs for sale
Postby 85levin » Fri Aug 18, 2017 10:11 pm
pm sent. glws
Re: Stuffs for sale
Postby totta crolla » Sat Aug 19, 2017 2:00 am
PM'd too !
aukword1
Re: Stuffs for sale
Postby aukword1 » Fri Aug 25, 2017 7:43 am
bump, added picture gallery link and some more parts. Will add more pictures later and pm/txt me if you want specific pictures.
aukword1
Re: Stuffs for sale
Postby aukword1 » Fri Oct 06, 2017 9:04 am
Bump added 4AGTE, T50 and megasquirt to the for sale.
mycrors4
Re: Stuffs for sale
Postby mycrors4 » Mon Oct 09, 2017 12:57 pm
Texted about the megan is rod ends an the PS knuckles
aukword1
Re: Stuffs for sale
Postby aukword1 » Wed Oct 11, 2017 1:02 pm
didn't get the text, try again or just pm me.
mycrors4
Re: Stuffs for sale
Postby mycrors4 » Wed Oct 11, 2017 11:12 pm
realized i texted the wrong number. just sent another!
aukword1
Re: Stuffs for sale
Postby aukword1 » Thu Apr 19, 2018 10:09 am
bump - added some parts
