which I check more often. If you want to customize your set (paint, halo, demon eyes, etc) to your liking, please inquire for more information.ACME SET
Price: $275.00 +Shipping to lower 48
A deposit of $100.00 is required to commission this project
PROJECTOR OPTIONS:
- ACME SUPER H1 Bi-Xenon
- ACME D2S Bi-Xenon
- E-46R Extended
- E-55R
- IRIS
- Mini Gatling (for H1 Projector only)
- Pilot H6054 Conversion House (Polycarbonate Lens w. Plastic Body)
- Nokya/Rampage H6054 Conversion Housing (Boroscillicate Lens w. Aluminum Body) +$75.00
- SIRIUS H6054 Conversion Housing (Polycarbonate Lens w. Aluminum Body) +$75.00
MORIMOTO SET
Price: $375.00 +Shipping to lower 48
A deposit of $150.00 is required to commission this project
PROJECTOR OPTIONS:
- Morimoto Mini D2S 3.0 Bi-Xenon
- Morimoto Mini H1 7.0 Bi-Xenon
- E-46R Extended
- E-55R
- IRIS
ADDITIONAL INFO
1. Retrofits do not come with Bulbs, Ballast or Bi-Xenon wiring harness (optional - if you don't mind splicing into your factory H4 highbeam input).
2. All retrofits goes through a thorough tuning and testing process before it is shipped out. Each individual headlight goes through a 6 hour "burn-in" cycle and gets submerged into water face down (lens side) for a minimum of 30 minutes to make sure it is completely sealed and there are no leaks.
3. Please advise, using ballast rated at 55w or above is NOT recommended for retrofits using ACME projectors as the increase in heat may risk burning the reflector bowl.
4. While most shrouds require little modifications to fit them inside 7x6 housings, certain shrouds (eg: Gatling 1.0/2.0) requires more work and would incur a small fee (no more than $15.00).
ORDERING
1. A deposit is required first before the retrofit can be started. The deposit is used to order a portion of the parts required while I cover the rest. This method is used in order for me to know, in good faith, you are committed to purchasing a set of retrofits. If for any reason you decide to cancel the project while work has already begun, a cancellation fee of $50 will be deducted from your deposit's refund. So once again, please make sure you are committed to the purchase.
2. It typically takes me 7-12 business days to finish a set once all the parts are made available to me which usually takes an additional 3-4 days to arrive.
3. During the entire retrofitting process, I will periodically take pictures of the progress and upload it to a Imgur album which you can keep track of. Pictures of the of the finish product will be shown before the remainder of the payment is finalized.
RECOMMENDED PARTS
BULBS (D2S Projectors):
Morimoto XB D2S Recommended kelvin 4500K-5500K
Morimoto XB D2H Recommended kelvin 4500K-5500K
OSRAM CBI or CBH (OEM)
BULBS (H1 Projectors):
Morimoto XB H1 Recommended kelvin 4500K-5500K
ACME H1 STANDARD Recommended kelvin 4300K-5000K
BALLAST:
Morimoto XB35 Ballast Ballast designated with 'D2S' are for D2S bulbs while 'AMP' ballast are for D2H/H1 bulbs
ACME SpeedyStart 35w
Denso Slim (OEM)
Matsushita Gen 4/5 (OEM) For D2S projectors only
BIXENON HARNESS
Morimoto MOTOCONTROL H4/9003 Optional - if you don't mind splicing into your factory H4 harness for the highbeam input, otherwise get this and everything will be plug 'n play
! IMAGE DUMP !
Morimoto MiniH1 7.0 | IRIS Shroud | Pilot Housing
ACME SUPER H1 | IRIS Shroud | Pilot Housing
Morimoto MiniD2S 3.0 | E-55 Shroud | Nokya Housing
ACME MiniD2S | E-55 Shroud | Pilot Housing
RANDOMS
Doge Tax
