20v BT 7age is build underway
98AE111
Re: 20v BT 7age is build underway
Postby 98AE111 » Wed Apr 23, 2014 6:33 pm
Which Stock ECU? Blacktop or 7AFE?
phanist
Postby phanist » Wed Apr 23, 2014 7:15 pm
Blacktop sir...
v33sonata
Postby v33sonata » Wed Apr 23, 2014 10:14 pm
im not sure who is asking what to who?....?
Postby yoshimitsuspeed » Wed Apr 23, 2014 10:38 pm
I know v33sonota already has a rod solution but for you other guys doing 7As I only need about 7 more people to commit before I can do a run of Brian Crower 7A rods.
phanist
Postby phanist » Wed Apr 23, 2014 11:02 pm
Sorry v33sonata i did not mean to jump in on ypur thread or any.. If any you would more about a 7ag then i ever could learn about it..
To those who wonder about the blacktop ecu on the 7ag bt ...im not sure if it would work... I just happen to have something which look like a 20v bt 7ag sitting in my garage so im thinking about testing it to see if it really work... That all..
v33sonata
Postby v33sonata » Thu May 01, 2014 6:57 am
LOL no worries! and I was told that the BT ECU would work just fine on a 7a bt conversion but it wouldn't be the best fit.
v33sonata
Postby v33sonata » Sat Nov 08, 2014 3:48 pm
Sorry for the delay! It's been a long awaited but she is ready for install. Hopefully I can find time before Christmas! For now enjoy the pictures.
Specs:
Stock Cams (for now)
83mm bore
JE 11.1:1 C/R Pistons
Eagle H-beam rods
Cometic 83mm Head Gasket
ARP Head Studs
ALC Bearings
techno toy tuning ITB's
Manon Timing belt pulley kit from http://www.battlegarage-rs.com/
Special thanks goes out To Grant @ battlegrage and Barry @ Manon Racing Products
phanist
Postby phanist » Sun Nov 09, 2014 12:47 am
looking good.. let us know how you like it..
any rear of engine shot? what water kit are you using?
v33sonata
Postby v33sonata » Sun Nov 09, 2014 6:00 am
phanist wrote:looking good.. let us know how you like it..
No its attached to the stand. I can take one when I put the clutch on before I install it in the car. What do you mean buy what kit are you using?
onnaj
Postby onnaj » Mon Nov 10, 2014 12:20 am
Wow that's a nice piece of an engine!!
But why did you use 83mm pistons right away? You would have no room in the future (or when something goes wrong with your build) to put even more oversized pistons in i think.
I'm really curious how it'll run with the blacktop ecu. I'm thinking of making a 7AGE 20V in the future as well with only an uprated block, but with a stock head.
v33sonata
Postby v33sonata » Mon Nov 10, 2014 4:49 pm
I have used this block for 2 other projects so I had to go 83mm as last time I went 82mm. But I did have it sonic checked and they said 83 is no problem. I might even to able to do 84mm.
v33sonata
Postby v33sonata » Wed Dec 03, 2014 10:50 am
phanist
Postby phanist » Mon Dec 08, 2014 1:07 am
danggggg are you running it with out the cooling system>? stock BT ecu?
congratz BTW
v33sonata
Postby v33sonata » Mon Dec 15, 2014 1:21 pm
LOL yea.... isnt it air cooled?
NO it was 1st start up making sure all worked before I added the other stuff.
v33sonata
Postby v33sonata » Mon Dec 15, 2014 1:42 pm
Enjoy the pictures.
And a video below
onnaj
Postby onnaj » Mon Dec 15, 2014 11:17 pm
Looks nice and runs well! You shouldn't only put as breather filter on the cam cover breather pipe, cause I think that's whistling :-)
v33sonata
Postby v33sonata » Tue Dec 16, 2014 8:05 am
I just ordered a red one :) and a set of ITB filters.
Postby yoshimitsuspeed » Tue Dec 16, 2014 9:31 am
Looks great
phanist
Postby phanist » Tue Jan 13, 2015 11:40 pm
what did you do to make that stock 20v header work>? with the rest of the exhaust system>? an adaptor>?
v33sonata
Postby v33sonata » Mon Jan 19, 2015 8:39 pm
Just bolted it in. I havn't had any issues.
JyuRoku
Postby JyuRoku » Tue Jan 20, 2015 8:20 pm
any dyno results yet?
98AE111
Postby 98AE111 » Thu May 24, 2018 8:50 am
Users browsing this forum: Google [Bot] and 2 guests
