20v BT 7age is build underway
v33sonata
Postby v33sonata » Fri Jan 10, 2014 8:34 am
It's been a while since I posted here but I will try and keep everyone posted. I had to find out alot of information before starting this build. But it's a go. I am converting my old forged turbo 7age motor to a 20v BT 7age. I got my pistons in yesterday and am running 11.1:1 C/R with an 83mm bore. I am keeping the use of my Eagle Hbeam rods. (So maybe nitrous in the future). My goal is to build a fun reliable car with some power. With a screaming redline and ITB I am sure I will achieve just that! If anyone decides to do this build and has questions just let me know. Enjoy the pictures:)
phanist
Re: 20v BT 7age is build underway
Postby phanist » Sat Jan 11, 2014 12:06 pm
Please explain more..
Im following
v33sonata
Postby v33sonata » Sat Jan 11, 2014 5:41 pm
Here is the custom piston info for anyone who cares to know. Keep in mind this is for my set up. I am using a set of Hbeam rods for a Honda and a 83mm bore cosmetic 1mm thick head gasket
Postby oldeskewltoy » Sun Jan 12, 2014 10:13 am
you have a lot of numbers there... some missing.......
What head gasket thickness are you using?
What is the final deck height?
What is the measured chamber volume?
Here is what we do know... 3.268 is bore, 3.366 is stroke, piston volume is -2.3cc
Also.... pin diameter of 21.01mm?? What rods are you using?? You said something about Eagle rods before
v33sonata
Postby v33sonata » Sun Jan 12, 2014 4:51 pm
oldeskewltoy wrote:you have a lot of numbers there... some missing.......
That would be all on the Machining paper work. I will get all that up when I go there. But if I recall we took 0.010 off the block from stock and the chamber volume was around 38cc but again going off memory. HG info as already posted.
The p/n on the Eagle rods are CRS5290H3D
Postby oldeskewltoy » Mon Jan 13, 2014 9:10 am
yep... I missed the head gasket.... Cometic 1mm
What I'm particularly interested in is the final squish (final distance of pistons edge to flat edge of head)
CRS5290H3D - appears to be a Honda B16 rod....
Are you using a OEM crank or an aftermarket crank?
v33sonata
Postby v33sonata » Mon Jan 13, 2014 4:57 pm
oldeskewltoy wrote:yep... I missed the head gasket.... Cometic 1mm
OEM crank. Yes it is a Honda b16 rod. When she is put back together and I get final measurements I will let you know. But I want to say it was like 0.006. Again just going off memory.
v33sonata
Postby v33sonata » Tue Jan 28, 2014 7:25 am
Motor was balanced yesterday. Hopefully I will have back later this week. Still waiting on custom timing gear for the crank tho. Apparently its on back order. and am still debating on what I want to do for timing belt and oil pump.
burdickjp
Postby burdickjp » Tue Jan 28, 2014 7:57 am
I'm going to throw a guess and say you turned a 7A crank down to take Honda rod bearings and fit the big end of the Honda rod?
Pursuing the ideal
v33sonata
Postby v33sonata » Wed Jan 29, 2014 8:19 am
burdickjp wrote:I'm going to throw a guess and say you turned a 7A crank down to take Honda rod bearings and fit the big end of the Honda rod?
You guessed correctly!
burdickjp
Postby burdickjp » Wed Jan 29, 2014 10:03 am
You beat me to this. Good job!
Your stroke, conrod length, and and compression height don't plug straight into the calculator I had for investigating honda rods in Toyota blocks, but my numbers could be wrong.
Your numbers do come out around the right deck height, though, at 206.0702mm
Which conrod bearings did you go with? I think there were two widths of bearing. Maybe the B16A was wider than OEM 4A and the B18C was narrower. I don't remember off the top of my head. I was originally looking at the narrower ones, which would have involved narrowing the big end of the rods.
Pursuing the ideal
v33sonata
Postby v33sonata » Wed Jan 29, 2014 7:24 pm
burdickjp wrote:You beat me to this. Good job!
Neither work actually. I had to grind down a set of ACL bearings to fit.
burdickjp
Postby burdickjp » Thu Jan 30, 2014 6:15 pm
v33sonata wrote:Neither work actually. I had to grind down a set of ACL bearings to fit.
Did you trim B16A bearings and the conrods to fit the 7A journal width, then?
Pursuing the ideal
v33sonata
Postby v33sonata » Thu Jan 30, 2014 11:09 pm
Yes on the bearings..... I dont think we had to do anything to the conrods. and I am pretty sure if we did anything we ground the crank a bit to make it fit. I could be wrong. It's been years and I dont remember. I'll try and find out tho.
Postby MisterJerk » Fri Jan 31, 2014 7:17 am
I also want to know.
Custom pistons with custom located wrist pin on b16 rods in a 7a block.
Im loving the innovation here.
v33sonata
Postby v33sonata » Mon Feb 03, 2014 8:06 am
Head anyone.......
phanist
Postby phanist » Mon Feb 03, 2014 8:36 pm
Nice head... Lol
Did you do any thing with the head?? Or u leaving the BT head in stock form?
v33sonata
Postby v33sonata » Mon Feb 03, 2014 8:48 pm
phanist wrote:Nice head... Lol
It's stock for now. Cams will be in the future but just want it running before I throw cams in.
phanist
Postby phanist » Mon Feb 03, 2014 11:07 pm
If i get my hand on a 4afe or 7a flywheel i will put this engine to a test...
redroku87
Postby redroku87 » Tue Feb 11, 2014 8:14 am
20V 7AGE with Poncams from Tomei?
Just an idea to throw out there.
v33sonata
Postby v33sonata » Thu Feb 13, 2014 6:47 pm
redroku87 wrote:20V 7AGE with Poncams from Tomei?
thats the plan
burdickjp
Postby burdickjp » Fri Feb 14, 2014 5:01 pm
thats the plan
Please keep us updated.
Pursuing the ideal
v33sonata
Postby v33sonata » Sun Apr 13, 2014 7:48 am
Hey Guys sorry for the delay in updating! I got got a new truck for off roading and it's been taking up most of my time. I did get my engine back fro mthe machine shop and I ordered in a timing belt gear. So hopefully here soon I will be putting her back together.
v33sonata
Postby v33sonata » Sun Apr 13, 2014 7:49 am
The head is in stock form for now.
burdickjp
Postby burdickjp » Fri Apr 18, 2014 7:17 am
Those are good looking pistons.
Pursuing the ideal
kaosboss
Postby kaosboss » Fri Apr 18, 2014 4:09 pm
Which timing belt are you using
v33sonata
Postby v33sonata » Wed Apr 23, 2014 7:54 am
kaosboss wrote:Which timing belt are you using
I havent gotten a belt yet but I am told I coult use the 4age 16v on with the new rekeyed crank pulley I have. I may have to modify the timing belt tensioner a little to make it work depending on what one I use.
Postby yoshimitsuspeed » Wed Apr 23, 2014 9:18 am
Yes the 20v cam gears are closer together so you can run the longer 16v belt. On a 16v 7A you need to run the longer alternative belt.
98AE111
Postby 98AE111 » Wed Apr 23, 2014 4:05 pm
phanist wrote:If i get my hand on a 4afe or 7a flywheel i will put this engine to a test...
Did you find a flywheel yet? I have one $100 plus ship from Jamaica. BTW what ECU you plan to use?
phanist
Postby phanist » Wed Apr 23, 2014 4:07 pm
Got one flywheel already but too lazy to pull the engine just test the 7ag...
Planing on stock Bt ecu btw..
