1990 corolla SR5
20V blacktop mated to the original 4AFE transmission
problem: six bolt flywheel won't fit the 8 bolt crank
can I source the flywheel header from US imported vehicles? for example can I use the twincam16 header from the AE86?
Also looking for MAP sensor
any direction on what car I can salvage these parts from would be great. Willing to buy private as well
thanks,
Mr.SR5valves
20v blacktop scavenger hunt help!!! flywheel header etc
Re: 20v blacktop scavenger hunt help!!! flywheel header etc
You can use a MAP sensor from nearly any 90s Toyota. I have a bag of them if you don't feel like going to the scrap yard. $10.40 and ill send you a couple.
thanks dude! the owner is going with a early camry MAP!
Happy to help. I always pull them off 93-97 corollas because they are so plentiful. I had to stop pulling them because I had an entire large zip-loc bag about to burst.
Will the 4AGEU header work? from the 83-87 4AG equipped AE86?
The header wont work directly, outer bolt holes don't line up. I've used the 20v header on a 16v so I imagine you can go the other way with some modification of the flange.
Flywheel you can use any 4AGE flywheel as long as you have matching clutch.
I can sell u the 20V Flywheel and Header just send me a pm.
Cant PM the site wont let me lets do this!!!! Whats your asking Price?!?!
ae86 is rwd, the 90 corolla sr5 is fwd. need fwd header. as for flywheel, source either a 200mm ae86 gts slywheel/clutch combo, of a 212mm flywheel/clutch combo from the later 4age's.
My turd of an 86
20v swapped 86 write-up
My turd of an 86
