Just bought a clean 16v off an mr2.
i was wondering which parts im able to transplant onto the mr2 engine from my old blown rwd bluetop off my 85 gts to make it this swap work
make a list if you have time of what i can keep to make this engine work.
thanks for your time and advice.
MR2 bluetop into Gts Q's
Re: MR2 bluetop into Gts Q's
The accessories might be different. You may have to use all of the 16v ones and none of the mr2's, or vice-verse. Check the pulley alignment.
swap your intake mani your water pump with backing plate and change ALL pulleys to the RWD pulleys. use the RWD header and install a pilot bearing in the crank. swap the coolant inlet and the coolant rear plate on the back of the head and your set. every thing else is the same.
there is one exception if you have the later red lettered valve covers or if you have the tan injectors then you will need to swap your injectors. but if it is the blue lettered valve cover and the injectors look the same as your old ones then your fine those will work.
