Hello all,
As I'm putting my 20V black top back together, a thought came to mind, if I am using the old 4AG brackets and accessories (alternator, AC, PS, etc) will I have to use the old water pump or will the 20V one line up with those pulleys?
Water Pump Line Up
Re: Water Pump Line Up
you will have to use the RWD water pump and pulley to line up with your RWD crank pulley. this is also recomended if you are going to reuse the mechanical fan since the FWD water pumps are not strong enough to hold the extra weight
- dr.occa
To reiterate what ga_goosh said:
Use either ALL FWD pulleys
OR
ALL RWD pulleys.
Don't mix & match them for proper belt alignment.
All water pumps will be fine if you're going e-fan.
RWD water pumps ONLY if you plan to bolt the clutch fan up to it.
OR
ALL RWD pulleys.
Will the RWD pump flow correctly with the SP-TEC water relocator?
