Hey guys,
Simply put I have a 16v smallport with a jdm smallport harness from a ae92. I am missing the map sensor. So basically I just a few compatible parts with #'s.
I need to know what the part numbers are for:
1. map sensor (or any other that will work)
2. Distributor cap & rotor (it is the jdm dizzy)
I have asked for this information a long time ago but I lost all the data on my computer. If anyone could help out, that would be great!
Thanks
jdm smallport pn's needed
Re: jdm smallport pn's needed
I'm not positive, but I think you can use the map sensor from a '91 corolla gts (smallport 4age) or a '91 corolla w/ 4afe (mine is map equipped).
these are cars in the united states correct?
- Rogue-AE95
I think people have used the 90-92 Corolla (4A-FE) MAP sensors with their 20v Blacktops. Same connector. Not sure about the JDM 16v smallport.
Jeonsah wrote:these are cars in the united states correct?
I forgot the usdm small port 4age was also afm so that won't work.
My '91 corolla le with 4afe has the map based setup though. I can pull the part # off the map sensor if you want.
Vic, didnt i give you access to toyodiy? you can look up the p/n's there...then do a reverse lookup to see what else they are on, in all countries.
My turd of an 86
20v swapped 86 write-up
My turd of an 86
Thanks morgan. I totally forgot about Toyodiy.... it got me everything + more than what I needed!
