Hello,
I'm completely cleaning my sludged 4AGE 20V BT engine and partly rebuild it were necessary. The piston rings, crankshaft bearings and conrod bearings look allright, but i think i might wanna replace them now when the engine is apart already.
The cylinders still got some hone marks, but i'm going to rehone them a little bit, so it'll be as new again. New piston rings i want to replace for sure then but if the crankshaft and conrod bearings aren't too expensive i might replace them too.
Who nows the BT OEM Toyota part numbers for:
1) The piston rings
2) Crankshaft bearings
3) Conrod bearings
Thanks!
Blacktop parts numbers wanted
Re: Blacktop parts numbers wanted
http://www.toyodiy.com will have al the bt part numbers. here is a link for starters.
http://www.toyodiy.com/parts/p_J_1996_TOYOTA_TRUENO_AE111-BCMVF_1301.html.
If you cant see the pics then create an account and make sure you are logged in and you will be able to see the pics. I cant tell you exact part numbers to buy since the parts you buy will be determined by your block pistons rods and crank.
Thanks, i can see what i need. Now i have to check my repair manual to see what marks i need
