Ive got a 20v silvertop with black top map/ecu. Wondering how I route the ICV with open throttles? Ive identified the outlet from the throttle manifold that feeds icv, also there is an outlet on the icv itself.
Thanks!
John
20v How do you plumb the ICV with open throttles?
Re: 20v How do you plumb the ICV with open throttles?
Outlet goes to the big port on the fuel rail...the intake port that connects to the stock plenum just put a small filter on the end so nothing gets inside of it
gaijin_rokurunner wrote:Outlet goes to the big port on the fuel rail...the intake port that connects to the stock plenum just put a small filter on the end so nothing gets inside of it
+10 rep points. Thanks bro.
- dr.occa
- Location: Texas ( user rating: 93% posts: 2409 - 1/11/13)
If it's what I think you're talking about; you know you could connect say a faucet valve that you would use for a gas line or an in line ball valve for plumbing, and by opening and closing it slightly actually adjust idle similar to how you would with an idle speed screw on carbs or a single throttle body.
