Hello,
i'm looking for all the 4AGE ST/BT Clutch numbers, so i can order them.
Do you advice the OEM clutch or aftermarket? I can get one from Daikin-Exedy prettty cheap, but don't know if those are the same as original.
4AGE ST/BT Clutch OEM parts numbers
Re: 4AGE ST/BT Clutch OEM parts numbers
get a clutch for an ae92 it will work with your st/bt
Do you happen to know the part number? I'm using the silvertop flywheel btw.
sure now these are oem part numbers and will be more expensive then aftermarket parts from your local parts house.
pressure plate is 31210-12151
clutch disk is 31250-12320
Thanks a lot!
