Mystery 4AGE Harness Not Cut--Missing ECU Plug 3?
Posted: Sun Aug 18, 2019 3:39 am
A buddy of mine has a 4age engine harness with the part number 82121-12400D which comes up as a 1986 AE86 GTS harness, The issue is that the harness is missing plug 3 for the ECU. It has plugs 1 and 2 but not 3. This clearly appears, to me at least, to be a USDM harness as it does have the AFM terminal connector. Now, according to the wiring diagram...the AFM wiring should run straight to the ECU as lines VC and VS. So, there's a AFM plug with wires that go to some mystery spot. This harness has not been cut. Is there a separate sub harness for that ECU plug 3 that we don't know about?
PICS of said harness
