OST-045: 5AGTE.... again ;)
As arrived. The head has been cleaned, but I don't know if it has also be pressure tested, so I'll be sending it out, along with all the associated bits to get cleaned and pressure checked before I start work.
The buckets and shims have seen better days... replacing them with good used units is far less costly then trying to salvage these
More to come.......
- Rogue-AE95
Re: OST-045: 5AGTE.... again ;)
1.7l?
How did those shims get what appears to be rust on them??
Rogue-AE95 wrote:1.7l?
somewhere over 1.7 liters... final size depends on their overbore.
rusty shims - Now sure... the head came to me cleaned, but everythjing else just came in a box. The shims, and the buckets carry a moderate level of rust, so these items will be replaced.
work begins.... de-burring the casting......
more to come......
working the first set of bowls and seats.....
more to come.......
2 down.... 2 to go....
more to come......
more to come......
Just about done on the intake side.........
more to come.....
more to come.....
next... the exhaust side....
more to come........
Chamber work has begun.....
more to come.......
3 chambers down......
sometimes the right tool is the simplest.... working the chamber wall with 120 grit.
more to come....
more to come....
Chambers done...... (for now)
work begins on the exhaust side.... one done... one under construction
more to come......
more to come......
- Rogue-AE95
That's a lot of material in the one port
Rogue-AE95 wrote:That's a lot of material in the one port
with a lot more to remove!
2 down... 2 to go
more to come....
Looking good....keep the pictures coming.
kaosboss wrote:Looking good....keep the pictures coming.
Ready for her multi angle......
more to come......
back from her multi angle....
more to come....
more to come....
looks very clean! Always, enjoy looking at your threads. What size cams are going into this?
Amazing work as always. How the heck do you get those shallow coolant passages around the chambers so clean?
mr2mk1hero wrote:Amazing work as always. How the heck do you get those shallow coolant passages around the chambers so clean?
One of the costs.... I have each head cleaned and pressure checked at a machine shop. In this case the head did come to me cleaned already, but I still had it checked for its pressure holding capability.
aukword1 wrote:looks very clean! Always, enjoy looking at your threads. What size cams are going into this?
This engine is getting a set of Cat cams 262, 230@ .050", with 9mm lift
- Rogue-AE95
I always like these topics, even if I don't post in them much. Great work as always
Rogue-AE95 wrote:I always like these topics, even if I don't post in them much. Great work as always
thank you kind sir.........
moving on....
Chambers currently @ 37cc. Now to decide what the final volume is to be, and then machine the surface to size. This head has not been machined since it left Toyota. Once machined we can move on to assembly, and fitting the cams.
more to come....
oldeskewltoy wrote:mr2mk1hero wrote:Amazing work as always. How the heck do you get those shallow coolant passages around the chambers so clean?
The machine shop that does the work is seriously impressive then. I took two heads so far to two different machine shops and neither could get the coolant passages as spotless as this.
mr2mk1hero wrote:oldeskewltoy wrote:mr2mk1hero wrote:Amazing work as always. How the heck do you get those shallow coolant passages around the chambers so clean?
Not all of the heads I work have this "pretty" of a finish from cleaning...
BUT... all heads leaving are machined so that you can read in their reflection... OR more appropriate - fully ready for a metal head gasket!
More to come........
ready for assembly.... with a pair of Cat camshafts
more to come.........
I put bigger valves in my 5AGZE head
Not sure if it was a good idea or not
(Some call it a 5.5ge)
Davegt27 Code One Racing
Davegt27 wrote:I put bigger valves in my 5AGZE head
The first 2(5AG) I've done I did with std valves... I MAY be working another one ... and that one the client is discussing running larger valves. Why are you unsure of your decision???
The head is getting shipped back to my client....
For shipping: With cam dummies in I can keep the shims I want in place without having the cams installed.....
- Rogue-AE95
That's a good idea! I know I've been saying this for years, but I look forward to sending you a 4A-GE head for work. It's all in the details like that ^
I can't report any big power gains for the added expense
Sorry for the late post I forgot about this thread
