Exhaust header type?
CloudStrife
Postby CloudStrife » Sat Jul 01, 2017 11:47 pm
Anyone know what brand this is? I know it's not factory as it's missing the 02 sensor bung.
I'm trying to figure out all the gaskets I'll need, after re-installing the header.
I seem to be missing 17300, VALVE; and 1719A, Gasket.
I just had the two gaskets after the VALVE: Gasket 17173, and 17177.
Do I need the first two? (17300, 1719A) Any ideas why it would be missing?
Thanks,
ian
Re: Exhaust header type?
Postby jondee86 » Sun Jul 02, 2017 12:10 am
According to this thread... http://www.club4ag.com/forums/viewtopic ... 205#p68162
... that is a TRD header (like the one on the left side of the pic).
The 17300 valve is the TVIS plate. The 17179A 8-hole gasket goes in front
of the plate and the 17177 4-hole gasket goes behind the plate. I guess if you
are using the TVIS plate you will need both gaskets. 17173 is the exhaust
manifold gasket, and you definitely will need that :)
CloudStrife
Postby CloudStrife » Sun Jul 02, 2017 11:46 am
Thanks Johndee! Perfect answer as always!
mad_86
Postby mad_86 » Tue Aug 29, 2017 12:25 pm
easy way to tell if TRD or OBX copy look at the EGR hole
TRD= Is straight up, egr lines up, perfect fitment
OBX= is at an Angle and won't line up, must bend egr pipe to fit
thats what i look for first, then the Collector TRD is a nice even collector, deep V
obx not so clean Short V collector
Users browsing this forum: carina4age and 3 guests
