valve buckets loose
valve buckets loose
Just realized I cant upload video.
I've got 272 / 264 cams in a used head that I don't really know the history of. Some of the shims I had to run were .128" and .130"
While checking clearance again to re adjust the shims, I found a bucket that was slightly loose (Intake #3, rear) and one that is quite loose up and down, and a bit side to side (Intake #4, front) . Intake #4 rear, and Intake #3 front is just fine. So its not isolated to a single cylinder.
Can the buckets get wore out, and need replaced with possibly larger od buckets? or is the head just scrap all the sudden.
86' Levin hatch
85' P-type Supra
87' MR2
85' Cressida
87' Cressida beater
85' P-type Supra
87' MR2
85' Cressida
87' Cressida beater
Re: valve buckets loose
You be $crewed!
If you had a rare engine, a machine shop could actually sleeve the bucket bores.
Time to look for another used head in better condition.
You need to find what caused the problem. I would do a close inspection, of the current valves, springs, keepers, relative to cam spec's, before swapping any of the parts into a new head.
Then compare that with what the cam Mfgr recommended valve train components should be used with your cam.
DaveW7
DaveW7
Pretty much as davew7 states... There are other options besides sleeving the worn bores... but all options typical cost more then finding another head.
There is another possible cause. Check to see if the cam has shifted f/A and is centered over the buckets Vs offset, which would cause the bucket to slide up/dwn Vs rotating. There could be enough tolerance is the cam lobe core to affect just a few buckets. Dave W7
Check with Loynings , they had to put 2 oversize buckets in my race engine at last refresh. Ya don't pitch a fully race prepped cyl head cause a couple buckets bores got sloppy.
Swiftdriver wrote:Check with Loynings , they had to put 2 oversize buckets in my race engine at last refresh. Ya don't pitch a fully race prepped cyl head cause a couple buckets bores got sloppy.
quite true.... In the OP's situation a replacement head may be less costly. Your head, has a great deal of time into it already, so overboring and using an O/S bucket is well worth the cost.
I agree totally, my point was that it CAN be fixed. You are correct in that it may not be economically feasible. I do however have a nice stock bigport head for sale cheap.
Users browsing this forum: No registered users and 8 guests
