RWD water relocation kit opinions?
Sprite
Postby Sprite » Mon Jun 12, 2017 2:35 pm
I'm thinking of purchasing the water connection relocation kit from Battle Garage for my Silvertop. I'm wondering if any of you have installed it and what your opinion might be. I see I may have to relocate the ISCV and I will also use their heater option. Right now my water lines run right past the header, not only crowded but adds too much heat to the system.
Rick
Re: RWD water relocation kit opinions?
Postby jondee86 » Tue Jun 13, 2017 3:01 pm
If you are referring to this kit...
... then you can get more information from the SQ Engineering website.
Sprite
Postby Sprite » Tue Jun 13, 2017 8:04 pm
Yes that's the one I'm looking to install, just wondering if anyone here has used it, fit, quality, etc.
Rick
shagymc
Postby shagymc » Mon Jun 26, 2017 9:48 am
I had the v3 installed on my BT. Install was fairly easy, though I removed my heater core so you'll have a couple more hoses to connect. Temps were steady and never had issues with it. All in all it was a great purchase and I found I liked it much better than the T3 version that was priced way higher.
Sprite
Postby Sprite » Wed Jun 28, 2017 4:21 am
Thanks Shagy that what I wanted to hear.
Rick
Mehmaddict
Postby Mehmaddict » Tue Oct 10, 2017 7:13 am
Hello,
I'm using this kit. It's perfect.
Easy to install, good quality,
My website is Turkish but you can check how its fit to my 20v blacktop:
https://ae86project.com/2014/12/29/20v-alisverisi/
Never Gets Old //
Sprite
Postby Sprite » Sun Oct 22, 2017 10:56 am
Thanks Mehmaddict, those pictures help a lot. I'm going to try to install the kit with the engine still in the car. We'll see if my fat fingers can fit in there.
Rick
Mehmaddict
Postby Mehmaddict » Sun Oct 22, 2017 11:19 pm
No problem mate, Some hints for you before install:
Check 2 sensor at the back and ready cables for them, It is very difficult to work here.
But It will be very hard to install this kit with the engine still in the car, Good luck!
Never Gets Old //
Users browsing this forum: No registered users and 10 guests
