extracted freedom ecu 16v ignition map
ditn
Postby ditn » Tue Aug 09, 2016 3:43 am
So i have extracted a 16v ignition map from freedom ecu that was lightly tuned
(Map based)
Do you think this map would be a good starting point for my stock engine with other cams?
goes from 500 to 9000 rpm other bar is mmgh/kpa
Freedom is bit different than other ecus
Re: extracted freedom ecu 16v ignition map
Postby oldeskewltoy » Tue Aug 09, 2016 8:29 am
ditn
Postby ditn » Tue Aug 09, 2016 11:58 am
id rather not blow up engine while doing the fuel map.
I did check most of those maps but i rather be 200% sure :)
Postby oldeskewltoy » Tue Aug 09, 2016 3:05 pm
keeping timing to 30 max doesn't hurt.... as far as fuel maps, that is an entirely different subject... and very few fuel maps will be matching....
Postby yoshimitsuspeed » Tue Aug 09, 2016 8:54 pm
That's what wideband gauges and knock monitoring are for.
ditn
Postby ditn » Tue Aug 09, 2016 11:00 pm
Freedom uses a unique fuel map system so im going to do fuel map myself.
In fact quite alot about freedom is unique.
I have a neko af700 and phormula knock system so im well covered in that aspect i think :)
