the road racer rebuild
I'm planning a TVIS 16 valve rebuild in my 87 GTS race car, planning on using mild cams, a litle bump in compression, leaning toward reliability more than HP, planning on keeping stock ECU, otherwise I'm bumped into class I don't belong How far can I go with the build before the TVIS gets in the way or is a small port head better
Re: the road racer rebuild
rocksteadyracer wrote:I'm planning a TVIS 16 valve rebuild in my 87 GTS race car, planning on using mild cams, a litle bump in compression, leaning toward reliability more than HP, planning on keeping stock ECU, otherwise I'm bumped into class I don't belong How far can I go with the build before the TVIS gets in the way or is a small port head better
What are the rules to your CURRENT class??? Frequently the rules allow little if any changes....
but if the only limitation is to run the original ecu... with proper parts mixing(ported head, cams, compression bump[pistons], injectors) you can boost power by about 25% to 30%.... maybe , just maybe if it is all done perfectly... you might be able to achieve a 35% gain... but it is highly unlikely with stock management to get to 35% improvement
am I better off with a small port head? I just never saw anything like these butterfly valves between the head and intake I am considering a megasuirt MSPNPS T8590
What rules are you following????
forget the rules focus on the build, the key is to build the car you want to drive and find a class it will fit in, we'er an amatuer club we race for plastic trophies, I race against a lot of sec miata s that cross into ITA, and some I can run with and others pass me like I'm standing still, who's cheating
the rules are co$t
rocksteadyracer wrote:forget the rules focus on the build, the key is to build the car you want to drive and find a class it will fit in, we'er an amatuer club we race for plastic trophies, I race against a lot of sec miata s that cross into ITA, and some I can run with and others pass me like I'm standing still, who's cheating
engine for running on stock TVIS based ECU(option1): ported largeport head, 256 cams, compression of 10.75 to 1, quality 4/2/1 header, 240cc injectors, exhaust diameter no larger than 2.25"
engine for running on stock TVIS based ECU(option2):ported smallport head, clip and flip smallport intake manifold, 256 cams, compression of 10.75 to 1, quality 4/2/1 header, 240cc injectors, exhaust diameter no larger than 2.25"
The smallport option will provide a bit more low end pull, but after that they should perform nearly identically. The largeport version is MUCH less obvious(harder to tell) as a "cheat"...
Either of the above engines should plant 120-125 wheel horsepower, or about 135-145 crank horsepower. The stock engine is rated @ 115 crank horsepower, or about 100 wheel horsepower. That should move you closer to the front of the field, but if you are looking to LAP the field... you might look at building something along the lines of this....viewtopic.php?f=7&t=1026 big budget needed for that
thank you my friend off to the biulder my pre build dyno was a hair under 100 hp
next off season one of your six speeds
