RLZ wrote:oldeskewltoy wrote:yes... standalone... easy enough to tell... ignition wires go to the intake side of the engine....
Why do you want 272 cams???
Oh yeah I just realized it haha, looks way cleaner without the dizzy! Bigger cam bigger power high rev? Haha I'm not sure maybe just 264s.
the longer the duration the cam has, the peak of the torque curve moves higher in the power band... In essence the point of most work happens higher in the rpm band. This can be good, or bad depending on what your purpose is.
In my engine I "stuck to" 264 type cams because I wanted a more daily-able engine... as you can see it makes plenty of power, and it makes it over a wide rpm range. In a race engine you are rarely driving it @ 2800-3500 rpm - daily-able rpm levels.
As to costs... I'm currently rebuilding a 4AGE for my new for me Corolla FX16. The engine ingested a spark plug electrode and now is getting rebuilt. Current costs $200 for bearings, and new rod bolts, $170 to clean the block, and clean and polish the crankshaft. I'll be using a Cometic gasket $88, and the rest of the gaskets and seals from Toyota $200. The block needed an overbore $150, and overbore means new, in this case - CHEAP, cast pistons $50. Rings are another $75 - again cheap because no premium ring exist anymore for this application. The block was also surfaced $150 to provide a zero deck. Since my machine shop has far more accurate/delicate instruments, I'm having them assembly the short block - $400. No oil pump yet($100-$160 depending on where, and what you buy)... the water pump was recently replaced, so I don't have to spend there. Now add in the work performed on the head - 30 hours of my time, and $300 for the 3 angle and surfacing.
so even with my connections I'm spending over $1850.........
