AE92 GT-S Bluetop to Redtop Swap (Wiring Harness Question)
bboy_RES
Postby bboy_RES » Tue Oct 08, 2013 3:32 pm
hey everybody. i'm getting ready to swap my bluetop 4age to a redtop 4age in my 88 AE92 GT-S and i'm wondering if the redtop engine wiring harness will plug directly into the bluetop interior wiring harness. I think i read somewhere that some guy did the same swap, but he had to replace the interior wiring harness as well. I'm hoping this isn't the case. any info is appreciated especially if you have experience doing the swap yourself! thanks in advance.
Crownvicman289
Re: AE92 GT-S Bluetop to Redtop Swap (Wiring Harness Questio
Postby Crownvicman289 » Mon Feb 10, 2014 9:23 pm
They're not plug and play by any means, but you can repin the harness to work. It'll require you to chop the last 6" or so off your old harness though.
sirdeuce
Postby sirdeuce » Sun Mar 09, 2014 8:49 am
Why "chop" 6" off the old harness? Identify the pins, pull them from the plastic connectors and 'repin' the old connector with the new harness.
One shot, one kill.
Crownvicman289
Postby Crownvicman289 » Mon Mar 17, 2014 10:23 am
The pins aren't the same style, so you'll need to chop and solder.
Rogue-AE95
Postby Rogue-AE95 » Mon Mar 17, 2014 2:33 pm
What about making a jumper harness? I doubt they're available to buy, but you may be able to get the connectors and make your own.
'88 Corolla All-Trac
Crownvicman289
Postby Crownvicman289 » Thu Mar 27, 2014 3:09 pm
You could do that, but it's cleaner to chop it and solder that last 6". If you were really badass you could get the pins and crimper, they do exist.
