Yes, you will need:
• manual rack
• brackets & bushings x2
• firewall shroud x2
• steering column (all I've found are non-tilt) **
• knuckles are supposed to be different, I have a set but never compared them to my PS knuckles
** If you have a tilt column with power steering, you will need to extend the splined end of the shaft that comes after the U-joint. I had a friend help me by cutting the shaft, then welding in a piece of round stock so that the PS column would reach the manual rack.
Here's a topic I posted years ago on the All-Trac wagon forum. The pics are still there, but have the Photobucket watermark now.
http://forum.alltracwagon.com/cgi-bin/f ... 44180/s-0/For my AE95 wagon, I had to drop the subframe in order to get at one of the rack brackets. It was a headache. FWD may be different.
