4throttle
comicparty90
4throttle
Postby comicparty90 » Sun Feb 10, 2013 5:12 am
Hi I'm from Malaysia,
currently using 4 throttle but don't have normal engine idling, when my car is warm rpm will show at 1.5rpm and when its hot it will reach 2rpm. how can I make it normal like usual idle rpm? Is it the iscv? what should i do? and should i install ficd for my aircond idling?
sorry for my bad english, i hope someone will teach/guide me thru all this problem.
Omni86
Re: 4throttle
Postby Omni86 » Fri Feb 15, 2013 10:24 pm
what is the year/make/model, engine-intake/fuel system of car with issue?
What is 4 throttle meaning? 4barrel carb?
May just be in need of a air/fuel or mechanical adjustment, or possibly a vacuum issue maybe, some more detail will help.
MisterJerk
Re: 4throttle
Postby MisterJerk » Fri Mar 15, 2013 12:42 pm
kinda sounds like he has a 20v 4age with ITBs.
Check vacuum lines, PCV valve, make sure intake manifold and stuff is tightly bolted with good gaskets. Your Idle control valve could be dirty. It could be linkage, etc.
LongGrain
Re: 4throttle
Postby LongGrain » Fri Mar 15, 2013 12:47 pm
Omni86 wrote:what is the year/make/model, engine-intake/fuel system of car with issue?
4 throttle means individual throttle bodies.
