Need to know if this transmission is an Lsd version and if anyone has put together axles from other yotas to work with this transmission on an ae92.
need help identifying this gze transmission.
Re: need help identifying this gze transmission.
Looks like an E-58, non LSD. If the bell bolts to a 4ag, it's most likely from an AE101.
One shot, one kill.
On the E series transmission the factory viscous lsd has the bar in the diff and the open diff has a small circular openning. The aftermarket diffs for the E series also has the small circular hole opening in the diff.
The only lsd axle that will work aside from the factory one is the mr2's lsd axle stub.
Thank you both, after further research and seller confirming that it's lsd tranmission.Now I need to find some lsd axles, can anyone help me get them.
You should ask around in mr2oc. Im positive the sw20 lsd axle stub works. You will need a shorter driverside axle. Chico race works sells a aw11 gze length axle.
http://www.monkeywrenchracing.com/produ ... ts_id=1252
Thanks for your help ae90tuner, will contact this vendors to who can help.
