Hello guys!
I'm wondering if someone has a CAI for a AE92 GT-S. I want pictures!
AE92 4AGE Cold Air Intake
Re: AE92 4AGE Cold Air Intake
I know I can google it. My real question is more, how did you do your CAI since there's no stock one for the FWD 4AGE. Is there a DIY somewhere?
DIY huh. Most of this is easy stuff. Aluminum 90* bend, 3/4" o.d. . 2 3/4" straight silicon coupling for the AFM to pipe interface, and a 2 3/4" x 2 5/8" reducing silicone coupling for the pipe to TB interface. Worm type or 'T' bolt type hose clamps to hold it together. Measure and cut the pipe. Be sure to remove all the chips and dirt from the pipe. Install it loosely so you can twist the pipe and make minor adjustments. Tighten the clamps. The parts can be had on ebay for under 20 bucks. For the filter side of the AFM, if you haven't done this yet, go to the wrecking yard and get an adapter from an AW11 MR2 and you can strap on a cone or mushroom filter. Make a support from flat metal stock you can pick up at your local Home Lowes Depot. AND, for the last bit, if you want to go this far, you can make a heat dam/isolator from just about anything you can form. I sandwiched mine between the MR2 adapter and the AFM.
One shot, one kill.
