TE72 brake question
TE72 brake question
Im converting my TE72 wagon to run ae86 front brakes. I'm wondering if I can run ae86 braided steel brake lines as well. Anyone have any insight?
Re: TE72 brake question
Any body out there?
yes you should be able to, I'm even putting rx-7 brakes on my E7 and im going to use ae86 SS lines
raviolikid134 wrote:Im converting my TE72 wagon to run ae86 front brakes. I'm wondering if I can run ae86 braided steel brake lines as well. Anyone have any insight?
yes... but that is NOT going to be your problem....
The E7 chassis is 12mm wider @ the strut mounts then an AE86. This means installing AE86 struts will automatically give you 6mm postive camber per side.
To "fix" the positive camber... you'll either need adjustable upper strut mounts, or longer (adjustable?) low control arms.
