AW11 mk1b rear struts
Rogue-AE95
Postby Rogue-AE95 » Mon Apr 28, 2014 3:06 pm
How difficult are they to come by? I know the mk1b has 2" diameter struts whereas the mk1a has 1¾" or so. I pulled a set from a junkyard '88 MR2 to use for something else, but it turns out I won't be able to use them after all. I hate to return them and see them end up turned into toaster ovens if they're not easy to find or desirable in some way to a mk1a MR2 owner. I'd basically only want to get my money back. I just don't know much about MR2s (thinking about getting an AW11 someday, though).
Re: AW11 mk1b rear struts
Postby yoshimitsuspeed » Tue Apr 29, 2014 5:40 pm
How much did you pay for them? I need some for R&D but broke is an understatement right now.
Rogue-AE95 wrote:How difficult are they to come by? I know the mk1b has 2" diameter struts whereas the mk1a has 1¾" or so. I pulled a set from a junkyard '88 MR2 to use for something else, but it turns out I won't be able to use them after all. I hate to return them and see them end up turned into toaster ovens if they're not easy to find or desirable in some way to a mk1a MR2 owner. I'd basically only want to get my money back. I just don't know much about MR2s (thinking about getting an AW11 someday, though).
Rogue-AE95
Postby Rogue-AE95 » Wed Apr 30, 2014 3:05 pm
Yoshi, I sent you a PM.
